Homeowner here, with a basic understanding of the NEC, but very little experience with other building codes. I am confused as to what makes something a porch, sunroom, patio cover, etc. and am hoping somebody will be able to help clarify. It doesn't help that porch and patio cover are not in the definitions section of the IRC.
I've currently got what I think is considered a porch? It is a 30x9' concrete pad out my back door that is covered under the main roof of the building. Here is a picture during construction, which is the only picture I happen to have of it on my phone. The wind is terrible here, and I've only been able to enjoy using my picnic table twice in the last year, so I would like to essentially enclose it with as much glass as possible to keep the open feeling, and a sliding door or two. I am picturing something similar to a commercial glass storefront, if I can afford something like that. I am not looking for an inhabitable space, or to leave it open to the interior of the dwelling, I just want to enjoy my porch in the wind. However, the couple of "sunroom" companies I've talked to insist that in order to close this in I am required to pay for an additional $2900 electrical package to add outlets every 12', which just seems ridiculous and unnecessary with my intent being to use this as a porch.
After digging through IRC for the past couple of days I was hoping it would be classified as a sunroom; then according to R301.2.1.1.1 I could identify it as Category II based on my intended use, and would be exempt by NEC receptacle outlet requirements per AAMA/NPEA/NSA 2100. Unfortunately for me, I just ran the numbers and even if all of those openings were solid glass, I would only be at 36.4% of exterior walls *and ceiling*, so it does not meet the 40% requirement in the definition of a sunroom.
So what does that make it? is it a Patio Cover, as per Appendix H (but not included in the definitions), which can be attached to the dwelling unit and be used for recreational outdoor living purposes? Seems to fit the my intended use and I would meet the 65% of "longer wall and one additional wall" glazed requirement, however it also seems to me that patio covers are really expected to be complete structures, and not under the roof of the dwelling unit. If it *is* considered a patio cover, it doesn't seem like NEC 210.52 would require the outlets every 12ft.
Is it still simply just a porch, and wouldn't be categorized as anything else by installing glass? Again, no extra electrical work required?
Now that I am thinking about it, the only way I can see NEC 210.52(A) receptacle spacing requirements coming into play is if it is considered a habitable space and part of the normal dwelling unit, which is definitely not my intent.
Thanks in advance for any guidance or clarification.
