Thank you, north star. I thought that was the case, as it would be logical. But i couldn't find a code section to back it up. Thank you!# = # = #
Yes, catch basins can be used as a storm sewer point of cleanout.
Typically, storm drain lines are larger in size to accommodate a larger
volume of water..........Unfortunately, the potential for trash, debris &
other to enter the storm sewer drain lines is quite high.............A roof
downspout connection can also be used, as an access point for a
high pressure, water jetting hose to be inserted in to the drain
line.
Check out the attached Link for some information related to
cleaning of storm sewer drain lines.
10 Important Things to Know About Storm Drain Cleaning
Storm drain systems are designed to move excess rain and ground water from paved streets, parking lots, sidewalks, and walking paths. These storm drains are usually fed by he street gutters, which are often fed by excess water flow coming from guttering systems on both houses and commercial...www.cloud9service.com
Ch. 11 in the International Plumbing Code provides guidance and
info on storm sewers.
2021 IPC 1101.8 Storm drain Cleanouts Required
