Should the cold be insulated for condensation?I have noticed in your pictures of plumbing that the hot pipe is not insulated.
California doesn't have a section R403.5.3 but California has the same rule somewhere else.R403.5.3Hot water pipe insulation (Prescriptive).
Insulation for hot water pipe with a minimum thermal resistance (R-value) of R-3 shall be applied to the following:
- 1.Piping 3/4 inch (19.1 mm) and larger in nominal diameter.
There is no room behind the drywall for insulation and the pipe.$ = $
Rembo, what do the plans require ?.........If the sheet type
insulation is what is required, then have the plbg. contractor
remove their piping, have the full, "non-hacked up" sheet
of insulation applied to all areas of the wall, then have
the plbg. contractor to install their piping in a compliant,
"non-lazy manner", and then have another inspection
performed to verify the re-do.
Exactly. That little bit of missing styrofoam can’t be a real problem.Is the Insulation require? In a 1A would it need to be there or is the block it's self sufficient?
It's not which is why we don't make a big deal about it. The main problem is that the block gets so hot, it heats the cold water.Exactly. That little bit of missing styrofoam can’t be a real problem.
I have encountered a heating issue with pipe in attics and on the exterior of the building. It can be significant. In your case the furred walls limit your choices. A thermal break might help. What do they do to mitigate the problem?It's not which is why we don't make a big deal about it. The main problem is that the block gets so hot, it heats the cold water.
Hurricanes, alligators, pythons, bugs the size of dinner plates, more lightning strikes than anywhere else on Earth and now this…. The average Florida H/O insurance policy is $6000 for a reason.The water down there is already hot right out of the ground.
There is. It's called framing the inside wall and not just using PT furring strips. High-end homes definitely use metal framing on exterior walls but the other 98% of the homeowners get furring strips.If the CMU gets that hot why is there not a better insulation method?
