Prescriptively Attach Metal Ceiling Framing to a Concrete Slab
How do you prescriptively attach metal ceiling framing or even false soffit to a concrete slab, whether post-tension or not? Is there a way to approve the addition of metal ceiling framing to a concrete slab in a high-rise building?
Not that I am aware of. Is there a way to do it without an engineer, maybe.
Depending on your state's licensing laws, an architect may be able to spec out the framing and specify a listed anchor for the attachment. Not prescriptive, but not fully engineered either.
"Prescriptively" means using information that's printed ("prescribed") in the building code. I am not aware of anything in the IBC, the IEBC, or the IRC that prescribes how to attach steel furring to a concrete slab.
How is the location of the tendons identified in a ceiling? I'll probably never need to know but I would really like to know.
Here is an example of when they didn't know there was a post-tensioned slab. It was an expensive mistake. There was more than what is shown.
Yep, we had two tendons snapped last year due to contractors not following the renovation plans.
That's terrifying.
I'm an architect as well as a BO. When I was in architecture school, we went to a building overlooking the construction of a new parking garage so we could watch the post-tensioning procedure. While we were watching, one of the clamps failed and the tendon (which was at just about full tension) released catastrophically. It launched a huge chunk of concrete across the width of the entire garage, where the chunk landed on the car of a salesman who was just leaving the site. He was killed instantly.
You just DON'T take chances with post-tensioned structures.
That's terrifying.
One of the contractors that was in the office today just told me about a high-rise building he was working in, another contractor hit one of the worst possible tendons and the damage was just over $3M because it involved several floors.
Has there been research as to how long the cables retain tension?
I'm curious about how a tendon could affect several floors. Did it happen repeatedly? $3M could be an exaggeration... I mean think about it ...$3M
We see restoration projects on post-tension buildings every 10-20 years and during that time they are checked & retightened.
How is the tension checked and to what value? “Retightened” indicates a loss in tension. What level of loss? Are there symptoms such as sagging floors, doors acting weird, etc.?
That doesn't look like post-tensioned concrete. That looks like pre-stressed concrete. In post-tensioned work, the tendons are in sleeves that are embedded in the slab (or beam). Once the concrete has fully cured, but before the shoring is removed, they attach a monster hydraulic jack to the end of the tendon and pull it tight to just short of the elastic limit, then they put a wedge-shaped plug around the end of the tendon and release the tendon, jamming the wedge into a socket. In post-tensioned work, I've never heard of one in which the tendons run in two directions.
