I continue to struggle with the difference between the two. Can I please get a simplistic explanation using a real-life example?
Ok, that helps. So, a torque is a specific type of moment. Basically, all torques are moments, but not all are torque.A torque is a moment about the axis of the member.
Thanks. I should check with leading universities with engineering curriculums and see what books they currently require for students.A textbook on strength of materials should help to clarify this issue.
I think I know why I always had such confusion. Let me put it into words based on my perception and correct me if I am wrong.
When a beam is under load, let's say a point load, the top of the beam under load is now in compression and the bottom is under tension. Somewhere between those two is a neutral axis. This is where I had my issue. When I see the word axis, I think of rotation, but that may not be fitting for a beam under load, correct?
So the fact that there is a bending moment in the beam, essentially a cause and effect, there really is no rotational torque around the neutral axis.
Am I thinking too much or is this about right?
A beam under bending rotates about the neutral axis
I agree with Mark because the top is under compression and the bottom is under tension which are rotating in opposite directions.??? How?
That doesn't sound right. If you have a cantilevered beam with fixity at one end, the bending is going to cause points on the beam to rotate about an axis through the fixed end.A beam under bending rotates about the neutral axis
That statement alone is insufficient, and the axis about which it would rotate is not the neutral axis.I agree with Mark because the top is under compression and the bottom is under tension which are rotating in opposite directions.
Certainly the sections of the beam rotate, but if you compare the deflected shape of the beam to its undeflected shape, I wouldn't generally call the difference "a" rotation.A beam under bending rotates.
A beam under bending rotates. This is a necessary consequence of the varying compression and tension stresses produced by the bending moments.
This discussion is an example of why I say the building official should be a licensed architect or engineer. If that is not possible the department should have an architect or engineer on staff.
Many of the building code provisions were written by engineers and it is common for engineers to submit calculations documenting code compliance. As a result in order to understand the code provisions and the submissions by the engineers you will typically need to see things the way an engineer sees them.
