The code says this: (posted for educational purposes under fair use)
(C) Cables Through Spaces Behind Panels Designed to Allow Access.
Cables or raceway-type wiring methods, installed behind panels designed to allow access shall be supported according to their applicable articles.
What it means:
Imagine you've got a room with a panel on the wall or a ceiling with lift-up tiles – these are designed so you can easily get to the stuff behind or above them, right? The rule here is about how to handle wires and cables in these accessible spaces.
If you've got cables or pipes (raceways) for wires running behind these panels or above these ceilings, you can't just let them hang loose or lay them on the ceiling tiles. That would be like leaving your tools scattered on a workbench – it gets messy and makes it hard to use the space.
Instead, these wires and cables need to be properly supported and secured. This is not just for neatness; it's a safety thing. Imagine trying to access a panel or lift a ceiling tile and having a bunch of wires fall on you – not good. So, these cables should be fixed in place following specific rules (like those in sections 300.11(B) and 300.23 of the code).
The same goes for other types of wiring like low-voltage, optical fiber, broadband, and communications cables. Just because they're not carrying a lot of power doesn't mean you can let them block access. They need to be neatly tucked away and secured, so they don't get in the way when someone needs to reach equipment or wiring behind these panels or above these ceilings.
What it means:
