JerseyJohn
GREENHORN
I posted here before about an issue with a detached garage monolithic foundation that failed final inspection for shape and height after garage was already constructed on top.
My specific code question: The 2018 (work was done in 2021) UCC in NJ (5:23-2.18) says that inspection of one or two family dwellings for which work must cease are:
ii. Foundation and all walls up to grade level prior to backfilling.
Questions:
1. Does this apply to detached garages? If not, is there somewhere else that applies?
2. Our town required that the monolithic be at frost depth (42 inches). Contractor got a footing inspection (passed) but not any other foundation inspection before building garage (unchecked boxes are slab and backfill on town form) Is this a code violation? Was he required to get a backfill inspection or some other foundation inspection by code before proceeding to build?
Most of the code seems to apply to block or stemwall foundations, so any other insight into what inspections or code a monolithic foundation requires would be helpful.
Thanks for any help.
Questions:
