New Section to the IPC: 705.2.4 Mechanical joints above ground.
705.2.4 Mechanical joints above ground.​
Mechanical joint couplings used above ground to connect ABS pipe to ABS pipe shall be of the shielded type and shall be marked by the manufacturer as being recommended for the application.
