mtlogcabin
Lubrizol (Orange) PVC fire sprinkler pipe is an example of where incompatible materials in contact with each other may cause pipe failure years down the road.Depending on both the material being penetrated and the penetrating material, simple "fire caulk" alone may or may not (probably not) be enough
Incompatible Products - Lubrizol
Lubrizol recommends that the compatibility of ancillary products be confirmed with that product’s manufacturer prior to use. The following products have been found to be incompatible with FlowGuard, BlazeMaster, Corzan, and products made with TempRite® Technology.
To avoid damage to the pipe and fittings, ancillary construction products coming into direct contact with FlowGuard®, BlazeMaster®, Corzan®, or products made with TempRite® Technology must be chemically compatible. Lubrizol recommends that the compatibility of ancillary products be confirmed with that product’s manufacturer prior to use.
The following products have been found to be incompatible with FlowGuard, BlazeMaster, Corzan, and products made with TempRite Technology. Please note: a product’s absence from this list does not mean that it is compatible. Products in this list are designated with numerals to clarify the reason they are listed as incompatible. The numerical designations are defined as follows:
