jaybrown
Has anyone come across a new manufactured house build with a perimeter frost footing and 4" slab (4-6" stone w/ 6 mil VB) mono poured with no interior pier footings?
What is your definition of manufactured house?Has anyone come across a new manufactured house build with a perimeter frost footing and 4" slab (4-6" stone w/ 6 mil VB) mono poured with no interior pier footings?
Yes, we've done thick slabs before, not just 4" along with piers where required by the manufacturer. I don't see them just put on a 4" slab even if the perimeter is frost protected. There are always piers somewhere in the middle.The state use to let them use a slab but now piers are required per manufactures installation directions.
We've had manufacturers specify piers in the center before, so it happens regardless of how self-sufficient the frame is perceived to be. Don't ask me why they spaced them out that way; I just reviewed the specs from the manufacturer when I was in Pennsylvania, and that is exactly how they were shown. This was routine for the specialty mobile home installers. Your mileage obviously varies.No piers needed for a single-wide mobile home. This is a trailer, with a totally self-sufficient structure. It's a different matter entirely from a modular, which meeds supports where the modules intersect.
Same way it does on anything else...how does a frost protected slab work on a mobile home?
It's not the heat in the building but the heat from the earth that keeps it frost free. A big insulating blanket that "catches" the heat from below. You can use frost protected shallow foundations for unheated buildings. Some different criteria - basically longer or deeper apron - but still works. And instead of extending out, that insulation at perimeter can go straight down - but you loose the simplicity of shallow excavation.I have zero experience with this, so how does a frost protected slab work on a mobile home? What's keeping the soil warm below the slab? Is there a heater under the floor of the mobile home? Just curious.
Threefold strategy typically:I have zero experience with this, so how does a frost protected slab work on a mobile home? What's keeping the soil warm below the slab? Is there a heater under the floor of the mobile home? Just curious.
"For buildings where the monthly mean temperature of the building is maintained at not less than 64°F"
I think you still need significant insulation under the slab in ground freezing climates such as MN, not just at the perimeter.It's not the heat in the building but the heat from the earth that keeps it frost free. A big insulating blanket that "catches" the heat from below. You can use frost protected shallow foundations for unheated buildings. Some different criteria - basically longer or deeper apron - but still works. And instead of extending out, that insulation at perimeter can go straight down - but you loose the simplicity of shallow excavation.
ps: 403.1.4.1 allows using ASCE 32 which includes the criteria for FPSF of unheated buildings.
Maybe....maybe not....."For buildings where the monthly mean temperature of the building is maintained at not less than 64°F"
That does not apply to this situation.
Yes, of course. Didn't mean to imply otherwise. In the ballpark of 2" if XPS under slab and 4' out. I guess you can leave out some underslab in heated but seems false economy.I think you still need significant insulation under the slab in ground freezing climates such as MN, not just at the perimeter.
Point takenMaybe....maybe not.....
Bills note here is part of what I was thinking:Point taken![]()
If it is inside the envelope and an empty floor it might work...But that is a weird one where technically we only have authority over the foundation and connections:heat it like a crawl space.
