Are Emergency Escape and Rescue Openings Required for Altered Basements?
Scenario Overview:
A basement that sustained fire damage requires significant repairs. The space includes a family room, a bedroom, and a bathroom. The basement has existing windows in the bedroom, bathroom, and family room, as well as a rear pedestrian door leading to an outdoor stairwell and an interior staircase connecting to the first floor. None of the current windows meet the emergency escape and rescue opening dimensions. The question arises: does the International Residential Code (IRC) mandate additional emergency escape and rescue openings as part of the repairs?
Code Compliance Analysis:
Under the 2018 IRC, Section R202 defines an alteration as construction or modification of an existing structure that goes beyond simple repair or maintenance. A repair, however, is considered the renewal or reconstruction of an existing part of a building to maintain or restore it, particularly after damage.
Section R310.6 clarifies that when an existing basement undergoes alterations or repairs, adding new emergency escape and rescue openings is not required unless a new sleeping room is created. In this case, reconstructing a damaged bedroom is considered a repair rather than the creation of a new sleeping room. Consequently, existing emergency escape and rescue openings can remain as originally built, provided they met the code requirements in effect at the time of their original installation, as permitted by Section R102.7.
However, Section R102.7.1 states that any new construction materials or elements used in the repair process must comply with the current IRC. For instance, Section R311 requires that any new egress components, such as staircases or doors, meet the standards outlined in the 2018 IRC.
Conclusion:
For this scenario, no additional emergency escape and rescue openings are required unless new sleeping rooms are added. The existing openings can remain compliant as per the code in effect at the time of their original installation. Any new construction must adhere to the requirements of the current IRC.
Scenario Overview:
Conclusion:
