The interesting thing is that I am not from Florida; I am from the cold climate north with frost depths. Your hypothetical "well-executed" thought is just that, a thought lacking reality. I tried to buy a ticket to Perfect World once, but I could not afford one. I then realized that no one can afford a ticket to Perfect World.The "proper" way to detail a slab on grade within the thermal envelope in cold climates (capillary break, under-slab and perimeter insulation, vapor barrier) is going to yield a dry location for conduit within it when well executed.
The actual way that slabs on grade are usually detailed in warm climates won't.
Cheers, Wayne
What I can tell you is that conduit below grade, even below a slab on grade, with or without a vapor barrier, fills with water. As a matter of fact, electrical embedded in concrete that is on or below grade has been known to fill with water. Each fitting is an opening waiting to be filled with water, including the water in the concrete as it settles.
You can post a reply to this and get in the last word, and create whatever magically perfect scenario you want. I will say, "Sure, it's possible." However, in the real world, NM cable in conduit below grade is a violation and will get written up as a deficiency in citing the correct code sections of the NEC. I am waiting for the day that a contractor appeals that violation and goes in front of the appeals board or building code advisory board and pleas their case to experienced professionals. Until then, the members of this board have lived in the real world, where this is a violation, and electricians know better than to pull NM cables through underground conduits. Hell, it is way harder to pull NM cable through conduit than it is THWN. That would be an act of stupidity.
I am departing this ridiculousness so please, have the last word.
