In building codes, not every term or phrase is explicitly defined. The provision addressing undefined terms ensures clarity and uniformity in interpreting the code. It states:
"Where terms are not defined through the methods authorized by this chapter, such terms shall have ordinarily accepted meanings such as the context implies."
This guidance highlights a hierarchical approach to understanding terms:
Understanding how to handle undefined terms is essential for ensuring compliance and consistency in the building industry. This provision empowers code users to make informed interpretations while adhering to the code’s purpose and intent.
- Ordinarily Accepted Meanings:
- If a term is not explicitly defined within the International Codes (I-Codes®), it should be interpreted based on its commonly accepted meaning. A standard dictionary definition often suffices, provided it aligns with the term’s context in the code.
- Context Matters:
- The meaning of a term should be inferred based on the specific context in which it appears. This prevents misinterpretation and ensures that the intent of the code is upheld.
- Specialized Terms:
- Some construction terms used in the code may not appear in standard dictionaries. In such cases, it is appropriate to refer to:
- Referenced Standards: Chapter 16 of the code includes referenced standards that may define terms used in specialized contexts.
- Published Textbooks: Technical books and industry-specific publications often provide detailed definitions and explanations for construction-related terms.
