jl3
Hi All,
We have an interior office project in CA (Palo Alto), using CBC 2022 and the question has to do with existing, not in scope, conditions that are non-compliant.
We originally did an interior renovation design earlier this year, got the construction permit approved and were on hold while the client discussed the budget. Unfortunately, they decided to drastically cut the budget and we're now renovating only the lobby finishes of level 1; the rest of the floor will now be out of scope. The intention is to amend the current permit with our revised scope, however I'm a bit nervous given how strict the AHJ is. In reviewing the existing permit drawings from 2018, the AOR at the time seemingly fudged their plumbing counts by calculating the entire 3 story building in total as opposed to calculating each individual floor; this wasn't an issue previously because we were adding sufficient plumbing fixtures. Based on a similar nearby project we did last year, the expectation is that the AHJ would require existing conditions to be shown, including egress and plumbing counts, in which case we would be depicting level 1 as being non compliant in regards to plumbing counts.
I'm essentially looking to see if there's any exception we can use to get around having to update things that are non compliant when all we're doing now is updating finishes in a lobby. We asked the AHJ if could use CEBC 2022 1009.1 as an exception and apparently chapter 10 has not been adopted by the city. Any input is appreciated.
