The Evolution of NM Cable Color Coding With Recent Changes
This article was approved by the Romex King himself, @chris kennedy who is buy running NM cable all day long and asked me to put this together for him. Enjoy.
Non-Metallic (NM) cable, commonly known as Romex® due to the brand that pioneered its manufacturing, has been a fundamental part of residential electrical wiring since its introduction in the 1920s. Over the years, its design and labeling have evolved, primarily to improve safety and make identification easier for electricians and inspectors.
Historical Overview of NM Cable Color Coding
Originally, all NM cables had white outer jackets regardless of wire gauge. This lack of differentiation sometimes led to confusion, requiring electricians to check the embossed markings on the cable jacket to determine the conductor size.
In 2001, the industry implemented a voluntary color-coding system to simplify this identification process. While not mandated by the National Electrical Code (NEC) or UL 719, the change was widely adopted across manufacturers. The following standard colors emerged for NM-B cables:
  • 14 AWG (14/2, 14/3)White
  • 12 AWG (12/2, 12/3)Yellow
  • 10 AWG (10/2, 10/3)Orange
This system allowed electricians and inspectors to quickly differentiate wire sizes, improving efficiency and reducing the risk of installation errors. Over time, 10/3 cable also adopted an orange jacket, further solidifying color-coding practices in the industry.
Recent Developments in NM Cable Color Coding
In recent years, manufacturers have introduced additional color variations for NM-B cables, particularly for configurations with three conductors. This was initiated by Southwire, a leading cable manufacturer, as a way to further distinguish different cable types.
The updated color-coding scheme introduced by Southwire is as follows:
  • 14/2 → White (unchanged)
  • 14/3 → Blue
  • 12/2 → Yellow (unchanged)
  • 12/3 → Purple
  • 10/2 → Orange (unchanged)
  • 10/3 → Pink
This revision makes it easier to differentiate between two-conductor and three-conductor cables, reducing confusion during installation and inspections.
Industry Adoption and Future Trends
Although these new colors are not required by the NEC, other manufacturers have started adopting similar changes. While not yet universal, this shift suggests that the industry is moving toward a broader acceptance of these new color codes. Electricians and inspectors should remain aware of these changes, as different manufacturers may implement variations over time.
Key Takeaways
  • NM cable has evolved significantly over the decades, with major changes occurring in 2001 to introduce color-coded jackets for different wire sizes.
  • Recent updates by Southwire introduced new colors for three-conductor NM-B cables, helping further differentiate them from two-conductor versions.
  • These color changes are not mandated by the NEC but are becoming more common as other manufacturers begin to follow suit.
  • Electricians and inspectors should stay informed about these industry developments to ensure accurate cable identification and prevent installation errors.
I asked Grok (X-AI) what the difference is between NM-C and NM-B cable. I got this answer:
The main differences between NM-C (Non-Metallic Sheathed Cable) and NM-B cable are:
  • Temperature Rating:
    • NM-B (NM stands for Non-Metallic, B for 90°C wire insulation) is rated for 90°C (194°F) for the conductors. This means the insulation can handle this temperature before it starts to degrade. NM-B is commonly used in dry locations and can also be used in wet areas if it remains dry during installation.
    • NM-C is essentially an older version or less common type where the specifics might vary by manufacturer, but generally, it's not rated for as high a temperature as NM-B. NM-C might have been rated for 60°C (140°F) for the conductors, which makes it less versatile for modern installations.
  • Usage and Locations:
    • NM-B is the standard cable used in residential wiring inside walls, ceilings, and floors where the cable will not be exposed to moisture. It's approved for use in dry, damp, or wet locations, provided it's protected after installation and not subject to direct moisture exposure.
    • NM-C was used similarly but less commonly now due to its lower temperature rating and potentially less robust insulation. Its use might be more restricted to specific applications or older installations.
  • Insulation and Jacket:
    • NM-B has a PVC (polyvinyl chloride) jacket that provides good protection against physical damage, moisture, and chemical exposure. The conductors are individually insulated, and the whole assembly is encased in this outer jacket.
    • NM-C might have different jacket materials or constructions, potentially less effective or durable compared to NM-B, though specifics can vary.
  • Modern Standards:
    • NM-B is what you'll find in current building codes and standards in North America, especially in the United States, for most residential wiring needs. It complies with modern safety and performance requirements.
    • NM-C is less seen in new installations because updated electrical codes have favored NM-B for its superior characteristics.
In summary, NM-B is the more modern and commonly used version due to its higher temperature rating, making it suitable for a broader range of applications in residential wiring. If you're doing electrical work, unless you have a specific reason or are dealing with an older installation, NM-B would be the cable to use. Remember, always check local building codes and standards before choosing your wiring materials.
  • Modern Standards:
I disabled the 12 url links that Grok put in your response.
