Ok, so a renovation project comes in, and the signed and sealed drawings declare a construction type that doesn’t make sense. The building’s been standing for decades, yet the design professional calls it Type IIB, or worse, a high-rise is declared Type VB, which is flat-out impossible. We rejected that one immediately. That’s not just a clerical error, and it has real implications for fire protection systems, structural elements, MEPs, etc.
In other cases, I’ve seen designs submitted as Type IIB, only to find that NM cable was used for wiring. When it gets flagged as a violation of the NEC, suddenly the RDP comes back and reclassifies the building as Type VA or VB just to make the installation “legal.” Are we rewriting the building’s construction type to backfit code violations?
And then there’s the opposite issue. An architect might guess high, labeling a building as Type I or II without evidence, forcing contractors to use all non-combustible materials, even when that wasn’t necessary or accurate.
One of the more interesting cases I had recently was a building that was clearly Type III. The project involved a Level 3 renovation and a change of use and occupancy. The architect labeled it Type II in an attempt to upgrade it for insurance reasons. Then the contractor ignored the plans and framed all the interior partitions with wood instead of the specified metal studs—essentially reverting it back to Type III without telling anyone.
The common thread in all of these? The declared construction type becomes a tool—sometimes a weapon. Whether it’s being manipulated to allow combustible materials, to bypass certain code provisions, or just to fit into someone’s idea of what “should” be there, it seems like we’re often left holding the bag to sort it all out.
So, how do you handle this in your jurisdiction?
- Do you verify the declared construction type against original records or field inspections?
- Do you push back when the declared type doesn't match the reality?
- How do you deal with mid-project reclassifications that are clearly done to make noncompliant work appear compliant?
- And when the contractor builds something completely different than what was approved, how far do you take enforcement?
