Calif. multifamily rec room warming kitchen - recirculating or no hood?
Yikes
Southern California
New apartment building in California, has a community room (multipurpose / "rec room") that has a warming kitchen are: refrigerator, sink, coffee maker. These spaces often have a electric (not gas) domestic range, though it is rarely used. It is certainly not used for cooking, only for keeping something warm.
This particular space has a significant problem getting a vented range hood to duct to the outdoors. The owner is asking:
  • Do the California Codes (energy, Mechanical, Green) require a non-residential range hood to be ducted?
  • Under what circumstances can the range hood be deleted altogether? Are there alternative warming devices (electric oven only, warming drawer only, or maybe an induction burner in the countertop just to boil some water) that do not trigger a requirement for a hood?
Due to Air quality issues, "I was told", in a seminar in Sacramento, Recirculating range hoods are no longer permitted in California.
I do not have a code section.....
Yeah, it's new in the energy code this cycle, 150.0(o)(1)(G) for single-family, and 160.2(b)(2)(A)(vi) for multi-family.
Man, talk about a messed-up numbering system. Fortunately, they're going to be completely re-organizing and re-numbering the energy code to make it more like the other codes.
Check out 2022 California Energy Code, Section 160.2(c), it looks like you have some options, but one way or another the space will need to be ventilated. I don't see anything that would specifically require a range exhaust system like the two sections I cited above.
Take a look at IMC 507.2.2 exceptions
    And just like building codes vary by setup, choosing the right payment gateway in pakistan depends on finding a solution that matches specific needs without unnecessary complications.
Hi,
In a similar setup I worked on, the deciding factor wasn’t the appliance itself but whether the space could ever be classified as cooking versus warming only so once we swapped the range for a listed warming drawer, the hood requirement dropped out entirely. This might helps
Hi,
Exactly. When Yikes said that the range would never be used for cooking, I thought that it should not be there.
