If there's a post already out there please link, I searched but came up empty.
In IRC Table N1102.4.1.1, General Requirements, it reads:
"A continuous air barrier shall be installed in the building envelope"
I believe this is usually accomplished with drywall with specifications to seal at joints, corners, etc.
"The exterior thermal envelope contains a continuous air barrier"
I'm having a tough time wrapping my head around this requirement but have read options such as OSB sheathing as long as the joints are taped (Zip system being an example) and WRB (house wrap) as long as the joints are taped.
Could the fiberglass batt insulation itself provide a continuous air barrier if it is kraft faced? Kraft facing is considered a vapor retarder (not the same as an air barrier I believe) and there are so many unsealed joints at each stud, top plates, etc. I don't see how insulation could fulfill the requirement for the "exterior thermal envelope contains a continuous air barrier."
So, I'm assuming the cheapest/easiest way (even if it's not the best way) to meet the minimum requirement is to ensure the WRB is taped at all joints. Is it really that simple or am I missing something?
