For the record, the underside of an exterior porch roof, or even of a carport, is considered exterior soffit.
So the exterior porch ceiling is an exterior soffit. Technically.I believe I agree.....And sometimes a ceiling...
How big is your deck?Is there a definition of a deck yet?
The 2024 IRC and IBC don’t define the word “deck” anywhere in Chapter 2 or elsewhere. But both codes are clear on what to do when a term isn’t defined. The IRC, in Section R202, says:Is there a definition of a deck yet?
I don't have a deck anymore. When I was married the first time, I had a big deck, then no deck after I got divorced.How big is your deck?
That explains the new profile pic.I don't have a deck anymore. When I was married the first time, I had a big deck, then no deck after I got divorced.
I agree. What's is a structure that looks like and is constructed like a deck that is not "adjoining" a house? I'm into some other sections of the IBC and LSC that use the words appurtenant and contiguous and it gets pretty subtle. So words like adjoining become important.The 2024 IRC and IBC don’t define the word “deck” anywhere in Chapter 2 or elsewhere. But both codes are clear on what to do when a term isn’t defined. The IRC, in Section R202, says:
“Where terms are not defined through the methods authorized by this code, such terms shall have ordinarily accepted meanings such as the context implies. The Merriam-Webster Collegiate Dictionary shall be considered as providing ordinarily accepted meanings.”
The IBC says almost the same thing in Section 202, just with a little more detail, stating that if a term isn’t defined in the code or any of its referenced codes, then the commonly accepted meaning applies, and Merriam-Webster is what you’re supposed to use.
So if someone is looking for a hard definition of “deck,” the code doesn’t give one. But Merriam-Webster does. It defines a deck as:
Deck: a flat floored roofless area adjoining a house.
That’s what the ICC points you to when the code comes up empty. And since “deck” is used throughout the IRC, especially in Section R507 on exterior deck construction, it’s fair to say that the ordinary meaning, backed by the dictionary, is what the code intends.
Does that mean a deck with a roof does not need to comply to the section on decks?Deck: a flat floored roofless area adjoining a house.
Don't get me started. Section 410 and other places. The definition is for 410 but it's use otherwise doesn't fit. A 40+ year struggle and why I'm working to rewrite section 410. Nothing to do with decks, porches, patios, etc.Canadian Code uses the term "deck," as well as "platform" - does IRC/IBC use "platform" in any meaningful manner?
It is a porchif it has a roof therefor it is not a deck,
AgreeIt is a porch
When using the UBC we used the word "platform" for a deck. We had to calculate our southern yellow pine deck spans by hand in those days. Guards and openings between railings were in another location I think, like the BOCA.Canadian Code uses the term "deck," as well as "platform" - does IRC/IBC use "platform" in any meaningful manner?
While that definition might work most instances so there would be an a. b. a gazebo might be placed over a deck, c. a rain cover or insect protective screen.The 2024 IRC and IBC don’t define the word “deck” anywhere in Chapter 2 or elsewhere. But both codes are clear on what to do when a term isn’t defined. The IRC, in Section R202, says:
Well there is also "pool deck" and "deck" attached to a pool house or a boat house. Recently, it was pointed out that "jurisprudence" or what the local circuit courts/superior courts or whatever court it is that does misdemeanor and felony charges and civil cases says is a deck. BUT, when the law is not clear "what is a deck", the ambiguity always in favor of the citizen against the government. Otherwise we go back to 11 century "Shire Reeve" where everything that is not spelled out is "an offense against the King". So we got Magna Carta, which gave us a legal system, not based on arbitrary decisions by the King.I agree. What's is a structure that looks like and is constructed like a deck that is not "adjoining" a house? I'm into some other sections of the IBC and LSC that use the words appurtenant and contiguous and it gets pretty subtle. So words like adjoining become important.
