Too many people in this industry think Tentative Interim Amendments are optional. They are not. A TIA is not a suggestion or a side note. It is an official part of the adopted code the moment it is issued by the NFPA Standards Council. When you adopt the 2023 NEC, for example, you are adopting the entire edition, which includes any TIAs that were issued and incorporated before printing. That is not up for debate. If the language of the TIA appears in the codebook your jurisdiction adopted, you are enforcing it.
This is where some professionals get tripped up. They assume that because their local ordinance adopted the 2023 NEC on a certain date, anything published after that date doesn't apply. That is false. TIAs are built into the document before it ever goes to print, and unless your jurisdiction explicitly removed or amended that section, the TIA is already part of the code you are using. There is no need to re-adopt it. It’s already there.
TIAs exist for a reason. They fix problems, close safety gaps, and respond to real-world issues. Some are temporary and have expiration dates, like the GFCI relief for HVAC units. Others are permanent clarifications to language that would have otherwise caused confusion or enforcement mistakes. Ignoring a TIA because you don’t understand how it got there or because it wasn’t part of the version you adopted two years ago is not just lazy, it’s dangerous.
Staying current with TIAs is part of your job if you are a contractor, inspector, engineer, or building official. The code is not static. The industry is not static. If a TIA is issued during the code cycle you are working under, it applies to you. And yes, it is enforceable. TIAs are not commentary. They are code.
