condo-owner
background:  this is for 1 story triplex buildings (each owner has their own complete wet system).  The flow switch test did not trigger the alarm in 13 of 58 units at a recent inspection. The buildings are 9-15 years old.  Most likely the alarm never worked since day 1.  No inspections have ever been done until recently.  Most of us are original owners.   Can you provide any best guess of likely causes?   Is the alarm required by code?   It is not connected to the fire department so it doesn't have a serious impact IMO.  Neighbors will just assume false alarm and go on their way!   This is the flow switch.  (It actually runs vertical.  I rotated the pic to read it.)   Is this a CRITICAL failure?
fwiw, The original builder's electrical contractor had a history of mis-wiring components along the way (e1 grinder pumps). I don't know if a builder would hire a Fire Protection company with their own electrician who would know what they are doing or would they possibly tap the builder's onsite electrician who was a bit sketchy. The reason I bring up wiring is because I saw a video of how to install a flow switch and I (not an electrician or even slightly mechanically oriented) saw lots of opportunities for error. Is mis-wiring a possibility? Do these sensors fail on their own over time? What else could be wrong?
Thanks for reading this. Appreciate any guidance with my many questions.
   This is the flow switch.  (It actually runs vertical.  I rotated the pic to read it.)   Is this a CRITICAL failure? fwiw, The original builder's electrical contractor had a history of mis-wiring components along the way (e1 grinder pumps). I don't know if a builder would hire a Fire Protection company with their own electrician who would know what they are doing or would they possibly tap the builder's onsite electrician who was a bit sketchy. The reason I bring up wiring is because I saw a video of how to install a flow switch and I (not an electrician or even slightly mechanically oriented) saw lots of opportunities for error. Is mis-wiring a possibility? Do these sensors fail on their own over time? What else could be wrong?
