codehelpneeded
2021 IRC, WA State
As an inspector, I commonly see no metal flashing above window trim. Usually the header trim is just caulked where it meets the siding. However, this does not appear to meet the requirements of the code (see below). Most local contractors install the metal drip edge but a lot of the companies that replace all the windows on your house in a day or two do not flash the trim. What are you guys seeing out there?
R703.4 Flashing.
Approved corrosion-resistant flashing shall be applied shingle-fashion in a manner to prevent entry of water into the wall cavity or penetration of water to the building structural framing components. Self-
adhered membranes used as flashing shall comply with AAMA 711. Fluid-applied membranes used as flashing in exterior walls shall comply with AAMA 714. The flashing shall extend to the surface of the
exterior wall finish. Approved corrosion resistant flashings shall be installed at the following locations:
1. Exterior window and door openings. Flashing at exterior window and door openings shall be installed in accordance with Section R703.4.1.
2. At the intersection of chimneys or other masonry construction with frame or stucco walls, with projecting lips on both sides under stucco copings.
3. Under and at the ends of masonry, wood or metal copings and sills.
4. Continuously above all projecting wood trim.
5. Where exterior porches, decks or stairs attach to a wall or floor assembly of wood-frame construction.
6. At wall and roof intersections.
7. At built-in gutters.
R703.4 Flashing.
