Amy Reineri
There are requirements for employees to have access to a place to keep their personal belongings while on shift - a locker. There is not a requirement for a locker room, though some places want them out of view or with more security from the public hallways. They could be put in another employee only area like a break room. But a locker room assumes the space is also a changing area - like down to your underwear. Dressing rooms are required to have ADA benches for this reason. If the locker area has no expectation of privacy and nothing to encourage it's use for changing clothing in a manner that requires privacy, then it's not a locker room - because no real dressing occurs. The route to - and heights of - the lockers need to be accessible, but no clothing change bench is needed. However, if a non-ADA clothing change bench is provided, they should either remove it or upgrade it to ADA compliant.A proposal for am A-2/A3 has come in. Within the space is a storage/mech. room. However within the room are employee lockers. It is largely an employee workspace for storage and equipment such as the water heater, CO2 tanks, and soda racks, but with a bank of employee lockers, ergo it is a room, with lockers. I see no way around the fact that at least 5% of the lockers must be accessible per 2018 IBC 1109.9. But would it be considered a "locker room" in the context of ANSI 117.1 803? The issue is that the room does not allow room for the bench required by ANSI 803/903 without some reconfiguration. Happy to cite that requirement, just want to be sure of the distinction between a locker being accessible vs. a designated "locker room".
