Taller single egress buildings?
So if I am reading this right Nashville can up to 6floor with a single exit. The travel distance is now defined as going from the furthest point all the way to the exit discharge. How on earth are you going to have a travel distance of 125ft with 6 stories. With the stairs being 25ft of travel per floor that already exceeds the 125ft limit, let alone the furthest distance on that floor. Are they allowing the door into a two-hour rated stair tower as an exit discharge from that floor.
I don't believe they have changed that...Some of them say 25' from the unit door to the exit enclosure...
I don't think I fully understand this:
6.20 Emergency escape & rescue openings served from a yard or court shall be afforded a 5’x 5’ unobstructed area at ground level.
Splat area from the 5th story?
And still no emergency lighting freaks me out especially after the Grenfell phone call audio...
I’m guessing it relates to setting up a ground ladder for rescue, to afford occupants on lower floors more options?
See this thread from a couple of years ago on the forum.
What I like about this document is that it helps explain that the single is about more than just saving ~15% of floor plate area; it's about being able to configure multifamily housing onto narrower lots, thus increasing the number of lots that can be developed. The apartment on the left requires a lot at least 75'-80' wide, whereas the the one on the right could fit on a 50' wide lot.
