International Wildlife Urban Interface Code (IWUIC) Guidelines for Protecting Eaves and Soffits
In areas prone to wildfires, protecting buildings from the spread of fire is crucial. The 2024 ICC Wildlife Urban Interface Code provides specific guidelines to enhance the fire resistance of structures. One critical section of this code is 504.3, which focuses on the protection of eaves and soffits. This article will explain the requirements of Section 504.3 and the associated commentary to help you understand how to protect these vulnerable parts of a building effectively.
Section 504.3: Protection of Eaves
Code Requirements:​
  1. Exposed Underside Protection:
    • Materials:
      • Ignition-resistant materials, or
      • Materials approved for not less than 1-hour fire-resistance-rated construction, or
      • 2-inch (51 mm) nominal dimension lumber, or
      • 1-inch (25 mm) nominal fire-retardant-treated lumber, or
      • 3/4-inch (19.1 mm) nominal fire-retardant-treated plywood.
    • Identification:
      • The fire-retardant-treated plywood must be identified for exterior use and meet the requirements of Section 2303.2 of the International Building Code.
  2. Fascias Protection:
    • Materials:
      • 2-inch (51 mm) nominal dimension lumber.
    • Protection:
      • Fascias are required and shall be protected on the backside by the materials listed above.
Understanding the Code:
Why Protect Eaves and Soffits?​
As a wildfire approaches a structure, the heat wave spreads horizontally along the ground and rises, concentrating beneath exterior projections such as eaves and roof overhangs. These areas are particularly vulnerable to ignition because the concentrated heat can easily cause them to catch fire. By protecting the underside of eaves and fascias, we can significantly reduce the risk of fire spreading to the rest of the structure.
Materials for Protection:​
  1. Ignition-Resistant Materials: These are materials that have been specifically designed or treated to resist ignition when exposed to flames or intense heat. Examples include certain types of treated wood or composite materials.
  2. 1-Hour Fire-Resistance-Rated Construction: Materials or assemblies that have been tested and approved to withstand fire exposure for at least one hour. This can include certain types of gypsum board, concrete, or fire-rated wood products.
  3. Nominal Dimension Lumber: Lumber that meets specific size requirements. The code specifies using 2-inch (51 mm) nominal dimension lumber for its inherent mass and ability to resist ignition. Additionally, 1-inch (25 mm) nominal fire-retardant-treated lumber or 3/4-inch (19.1 mm) nominal fire-retardant-treated plywood can be used. These treated materials must meet the exterior use requirements of Section 2303.2 of the International Building Code, ensuring they are suitable for outdoor conditions and capable of resisting fire.
Fascia Protection:​
Fascias, the vertical finishing edge connected to the ends of rafters, trusses, or the area where the gutter is attached to the roof, must also be protected. The code requires fascias to be protected on the backside with the same materials specified for the eaves' underside. This additional protection ensures that even if flames or intense heat reach the fascias, the materials will help prevent ignition and fire spread.
Code Insights:​
The commentary further clarifies why these measures are essential. When a fire approaches, the heat wave can become concentrated under eaves and roof overhangs, making these areas prime targets for ignition. By using fire-resistant materials or sufficiently thick lumber, the risk of ignition is significantly reduced. This proactive approach to fire protection helps safeguard the structure and improves its chances of surviving a wildfire.
In Summary:​
Protecting eaves and soffits is a critical component of building fire-resistant structures, especially in wildfire-prone areas. By adhering to the requirements of Section 504.3 of the 2024 ICC Wildlife Urban Interface Code and using appropriate materials, builders and homeowners can enhance the resilience of their buildings against wildfires. Understanding and implementing these guidelines not only complies with the code but also plays a vital role in protecting lives and property from the devastating effects of fire.
Note that hot gas and/or ember ingestion into the attic via soffit vents seems to be a factor in total losses in residential buildings sprinklered to NFPA 13R as well (not fatal fires, as they generally start _outside_, but they do total the building out). These requirements (or just straight up rolling with an unvented/conditioned attic) might be wise to apply in that context as well...
One of my first tasks in this business was to use some of my former journalism skills to create a document/guide to help folks adapt to climate change. As a result of the research, I significantly altered the soffit design of my house.
The hidden danger is the prolific use of vinyl soffits. Vinyl in any form (soffit/siding/whatever) on a house should be banned - the stuff is basically firestarter. Seen way too many total loss homes where a bit of fire got to the vinyl, and almost instantly went up the side and into the attic.
