RJJ
Co-Founder
Would the alarm control panel for security need to meet the 48" reach range requirement under IBC 2006 1109.13?
You may wish to read the advisory material in the appendix to ADAAG regarding section 4.1.1(3) before you leap to the wrong conclusion.Gene Boecker said:brudgers, I wish you'd limit your conversation to things you know.ADAAG exempts employee areas under 4.1.1(3).
IBC exempts employee areas under Section 1103.2.3 :x
The famous "trained personel" exemption to ADA.Gene Boecker said:I'd venture to say that most alarm/security panels are NOT for use by all - only trained personnel.
The famous "trained personel" exemption to ADA.brudgers said:Gene Boecker said:I'd venture to say that most alarm/security panels are NOT for use by all - only trained personnel.
Of course, the nature of the employee area exemption in current law is pretty clear.Gene Boecker said:True, the DoJ is re-reviewing the draft and massaging a few things here and there. However, from what I've heard, most of the proposed changes are not in the ADAAG (technical) portion of the rule-making. The changes are mostly in the enabling/ threshold provisions. In the end, we shall see when it finally comes out - hopefully next year. However, although the DoJ will give the "party line" (remember, they're a bunch of attorneys) that the new document isn't adopted and can't be used yet (except for those specialized projects where the government has adopted it), the Access Board is consistently re-affirming the fact that where there are void in the preset ADAAG or areas that are not clear, the new document can be used as a guideline to determine intent.
And now, I think we've exhausted this topic - sorry for the hi-jack.
And of course:http://www.access-board.gov/ada-aba/final.cfmEmployee Work Area. All or any portion of a space used only by employees and used only for work. Corridors, toilet rooms, kitchenettes and break rooms are not employee work areas.
Work Area Equipment. Any machine, instrument, engine, motor, pump, conveyor, or other apparatus used to perform work. As used in this document, this term shall apply only to equipment that is permanently installed or built-in in employee work areas. Work area equipment does not include passenger elevators and other accessible means of vertical transportation.
Your argument was much stronger before you made it.http://www.access-board.gov/ada-aba/final.cfmAdvisory F205.1 General. Controls covered by F205.1 include, but are not limited to, light switches, circuit breakers, duplexes and other convenience receptacles, environmental and appliance controls, plumbing fixture controls, and security and intercom systems.
Remember the important thing isn't that I'm right.Gene Boecker said:blah-blah-blahVolo vomito
Remember the important thing isn't that I'm right.brudgers said:Gene Boecker said:blah-blah-blahVolo vomito
I guess it must have been in another thread.Gene Boecker said:The Fire Alarm Control Panel does not need to meet the reach ranges in the ANSI or ADAAG. The FACP is not intended for use by the employees or users of the building. Although it is generally located in a public space, it fits into the category of an equipment space per 1103.2.9. Therefore, reach ranges are not required. Mounting heights per NFPA 72 are the only requirements.
Because it certainly wasn't in this one.Gene Boecker said:I'd venture to say that most alarm/security panels are NOT for use by all - only trained personnel.
That much is obvious.Gene Boecker said:Further, if you read the draft 2004 ADAAG it is intended to clarify the text to be almost exactly what the IBC says now. It has nothing to do with structural anything. That's an entirely different issue.
Maybe it will happen someday.Gene Boecker said:The Access Board and DoJ have affirmed the fact the electrical panelboards in commercial establishments fit this category. If the alarm/security panel is similarly used, it should be similarly treated.
