gtyler75
Situation: residential units at an inside corner of the building. Trying to meet glazed area requirements but have limited linear exterior dimension.
Proposed solution: Notch in the exterior wall at the corner (~2' both sides)(see crude diagram below). This way, we can fit a larger glazing unit without increasing the unit width.
Question: I read through the code commentary (IBC 2018), and can't decide whether this situation still qualifies as a "yard", or if the partial wrapping on the open two sides would create a "court" condition. There would not be glazing on the partial two sides.
Basically, is this an all or nothing situation, or is there some allowance for projections/obstructions required for a yard?
Thanks in advance.
| unit |
unit |___________|
_________| |
? | unit
__|_______________
ext. |
| unit
Thanks in advance.
| unit |
unit |___________|
_________| |
? | unit
__|_______________
ext. |
| unit
