TimNY
Platinum Member
Trying to get up to date on the new energy code we'll be using here.
Does anybody have any recommended reference material? I looked at iccsafe and there are 4 different books on the 2009 IECC that look like they might be good.
I am trying to figure out a few things:
"an air barrier extends behind [electric] boxes or air sealed type boxes are used"-- in the case of boxes on the interior side of exterior walls, this would not apply, correct? I interpret this to mean boxes on the exterior side of exterior walls (ie for exterior receptacles or exterior wall fixtures) would need to be sealed.
"an air barrier is installed at any exposed edge of insulation"-- this is *edge*, right? ie in the case of insulation in a floor above an unconditioned basement, an air barrier would not be required on the underside of the insulation?
"an air barrier is required behind tubs and showers on exterior walls"-- ok, i get this.. but is an air barrier required between a room and the exterior wall anywhere else?
thanks in advance,
Tim
thanks in advance,
Tim
