The building is a multi-story Type I-A, fully sprinklered construction.
The exterior wall does not require any fire resistance rating, more than 30’ open yard.
The makeup of the exterior was is exterior brick veneer, 12” block, sprayed on foam insulation, metal stud with an interior sheetrock finish.
I have been going in circles trying to decide if the foam insulation is part of the so called non-combustible wall, or something else. The foam meets the testing requirements of chapter 26, and has the thermal barrier; however my comfort level is just not there. It just seems if a designer wants to make something better, improve insulation, and it meets the flame spread and all that good stuff it should be ok. On the other hand, if you look at 602.3, for Type III construction, just for S&G and thinking equivalencies, exterior walls are also Non-combustible and specifically only allows FR lumber in the wall assembly. It does not benefit from 603. My thinking is that if the foam was an integral part of the assembly, say it was sandwiched in the non-comb assembly, now we have a different issue, but added on to the assembly leave me with some questions. So what am I missing.
