Please include the violations with code references. Thanks in advance.
250.12 Clean Surfaces. Nonconductive coatings (such as paint, lacquer, and enamel) on equipment to be grounded shall be removed from threads and other contact surfaces to ensure good electrical continuity or be connected by means of fittings designed so as to make such removal unnecessary.
Oh and there is a label on the door that might specify a ground bus. Then again, that lug could have been factory.
There were none, other than 250.92
It appears that I took too long before hitting the 'post reply' button. Don't think I can edit my previous post.
No Sir, It is to run the sewer pump during a renovation of a lift station for the sewer authority.IS a tower crane on site? that was the only time I ever inspected a temporary service of this size.
