Augustina
Vigas are traditionally used in support of flat roof construction in the southwest.  The NM residential building code was recently revised to include a span chart specifying the number and span of vigas based on the nominal diameter mid-span with a minimum of 5 in diameter. The code refers to the Section R802.1.3 Structural log members, which states that the log members must comply with the provisions of ICC 400, and adds the span chart.
It seems that complying with the ICC 400 would require the viga to be graded especially as
the span of vigas serve as the main structural member that support the roof and transfer its weight to the exterior wall.
Table R802.1.3.1. The New Mexico Viga Span Chart includes, “Vigas shall have the bark removed to visually inspect for straightness, bending, splitting, loose knots or rot which would reduce strength.” However, it does not say who is responsible for inspecting for these defects or to what degree the presence of any of these defects would deem the log (viga) unsuitable.
I am being told that vigas do not have to be graded as long as they are installed according to the span chat.
I am not an expert, my roll is in communicating this span chart in a newsletter and other communications. I am uncomfortable reporting that vigas do not have to be graded but I do not have the expertise to argue the point. I have attached the revised code, if anyone is interested in offering an opinion or perspective. Thanks!
