Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,568
2012 IBC, 1008.1.9.8
Item #6 says the entrance doors in buildings can't be secured from the egress side during periods the doors are open to the general public. The commentary to this section says that those doors will not require the use of the system.
In a tenant suite, with main public entry doors, a mag-log complying with all of the other provisions of 1008.1.9.8 is installed. Is this compliant? On one hand, the door is not secured from the inside via all of the mechanisms listed in the code section. On the other hand, the system is still engaged. Or, does this section only apply to the main building doors, and not to the individual tenant spaces?
If a timer is installed as part of the system to disengage the entire system would that be compliant........or is the timer now part of the system?
This stuff hurts my brain.
