LGreene
I haven't found anything in the accessibility standards that addresses keys, or locks operated by keys, and I've heard that this is because the key is not a permanent part of the door/hardware and is therefore not covered. But if a lock requires a key for operation, it seems like it would be difficult for someone with a disability to operate it. I've seen deadbolts that use a keypad instead of a key, but you have to turn a turn-piece to retract the bolt. This may be easier for someone to operate than inserting and turning a key, but the turn-piece may not be considered accessible depending on who is evaluating it.
I would appreciate your thoughts on this. Is it ok to install a key-operated lock knowing that it may be impossible for some users to operate but is not officially addressed by the ADA, or would it be better to install a keypad-operated lock with a turn-piece that is easier to operate than a keyed deadbolt but may not be operable by anyone. Is there anything in writing about the ADA's stance on keys?
