Paul Sweet
From the Access Board website FAQs: http://www.access-board.gov/adaag/about/FAQ.htm#hgb1
"4.26 Handrails, Grab Bars, and Tub and Shower Seats
1) Q: Can I use standard pipe for handrails? (ADAAG 4.9.2)
A: Yes. Common IPS pipe sizes designated as 1-1/4 to 1-1/2 are considered to be within the dimensional tolerances for handrail diameter."
I think the problem started when ANSI put metric equivalents to nominal dimensions without thinking of the actual dimensions. If you want to be literal about the 1 1/4" - 1 1/2" diameter, then only 1" nominal pipe (1.315" O.D.) is acceptable. Even 1 1/4" nominal pipe (1.660") is too big. I'm glad that ANSI and the Access Board finally corrected this, even if it took almost 20 years.
