Yikes
Looking for some practical advice as well as technical assistance. I have some affordable (public housing) apartments where the only door configuration that provides enough clearance at a bedroom and/or bathroom is a sliding (pocket) door, as allowed by CBC 11B-404.2.4.2.
I know the clear width in the open position must be at least 32". I also know per 11B-404.2.7 that the hardware must be exposed and usable when the door is int he fully open position.
Q1: In practice, does the recessed cup style of hardware comply? Some people use their finger tips; I might be able to use (for example) an arm stump, but pressing into the cup might add to the friction of the sliding hardware?
Q2: If I use a conventional "D" shape door handle mounted on the stile, how much clearance should I leave between the handle and the door jamb. Should I plan on a 38" wide opening to leave 32" clear with 6" to spare for the stile edge, handle width and clearance to jamb? Or will a 36" wide door suffice?
Q3; Are there pocket door privacy locks that are ADA compliant?
