mark handler
ADA Angst over pavement preservation
Posted By Tom Kuennen On October 9, 2014 @ 11:22 am In In the Magazine,Road Science
Pavement preservation stakeholders in the United States are concerned that a reinterpretation of the Americans with Disabilities Act last year by the U.S. Department of Justice (DOJ) and U.S. Department of Transportation (DOT) will lead to disruption of low-cost pavement preservation programs in this country.
The technical advisory requires that curb ramps and other upgrades be mandated for a variety of thin pavement preservation surface treatments that heretofore had been defined as maintenance, and therefore did not require upgrades until alterations were made to the road.
This unfunded mandate could set the pavement preservation mantra of “the right treatment to the right road at the right time” on its head, with cost pressures resulting in the wrong treatment to the wrong road at the wrong time, or no treatment at all if the ADA curb ramp installation costs are too high.
But at the same time it could lead to a reassessment of an agency’s compliance with the ADA as the agency inventories which intersections need remediation, and which don’t, regardless of the status of its pavement preservation program.
Title II of the Americans with Disabilities Act of 1990 (ADA) requires that state and local governments make sure that persons with disabilities have access to the pedestrian routes in the public right-of-way. An important part of this requirement is the obligation that, whenever streets, roadways or highways are altered, curb ramps be provided where street level pedestrian walkways cross curbs.
Pictured is a regulation curb on a suburban street. An important part of this requirement is the obligation that whenever street, roadways or highways are altered, curb ramps be provided where street level pedestrian walkways cross curbs.
For decades, states, counties and municipalities should have “ADA plans” in place, thus have a program for providing curb ramps, in many cases installing curb ramps even without the trigger of pavement “alteration.” Programs for curb reconstruction to provide curb cuts without associated pavement reconstruction has kept these agencies ahead in the game.
During those same decades, the pavement preservation movement gathered steam, and now many preservation programs are in place at all levels of government, with pavement inventories and condition databases used to program preservation work. But, the new ADA guidance from inside the Beltway does not take the existing ADA plans into consideration, and the guidance creates contradictions in prioritizing ADA work and pavement preservation programs.
Preservation saves roads, money
Proponents maintain that pavement preservation techniques are cost-effective and environmentally sustainable strategies that extend the life of pavements before they deteriorate substantially. They add that pavement preservation is like changing the oil in your car, or painting your house: a smaller upfront investment avoids high future costs of reconstruction and rehabilitation.
For roads, these techniques include preventive maintenance surface treatments such as slurry surfacings, crack sealing, chip sealing, micro surfacing, surface rejuvenation, hot and cold in-place recycling, thin-lift hot-mix asphalt paving, and concrete pavement restoration.
Local governments now must recalibrate their pavement preservation programs to accommodate the cost of compliance or change strategies completely. An ideal curb ramp that meets ADA requirements is shown.
Pavement preservation methods prolong pavement life, says the National Center for Pavement Preservation (NCPP), avoiding high future costs of reconstruction or rehabilitation through the expenditure of lesser amounts of money at critical points in a pavement’s life. Experience shows that spending a dollar on pavement preservation can eliminate or delay spending $6 to $10 on future rehabilitation or reconstruction costs, NCPP says.
Previously, pavement preservation treatments weren’t considered road alterations that would trigger ADA requirements. But following the new guidance released last year, under the ADA, some pavement preservation treatments now require costly accessibility features such as curb ramps be installed as part of the project, while other preservation treatments don’t.
Projects now deemed to be alterations must include curb ramps within the scope of a project. These include micro surfacing, thin-lift overlays, open-graded surface courses, cape seals, mill-and-overlays, and hot in-place recycling.
Projects deemed to be maintenance, and exempt from curb ramps, include crack and joint filling and sealing, surface, chip, slurry, scrub and fog seals, concrete joint repairs and dowel bar retrofits, spot high-friction treatments, undersealing, diamond grinding, and pavement patching.
“This recent DOT/DOJ interpretation changing long-standing FHWA practices threatens to take away several cost effective maintenance ‘tools’ for government agencies,” said FP2 Inc. executive director Jim Moulthrop, P.E. “Our experience is showing that the right treatment, for the right road, at the right time, is put at risk by the new ADA guidelines, which can even lead to no treatment if it’s perceived that the right treatment would lead to unaffordable capital improvements. This is counterproductive to road maintenance programs achieving ADA goals, and flies in the face of the pavement preservation language of our federal surface transportation legislation, MAP-21.”
Survey shows California impact
That’s borne out by a survey this spring of local governments in California that shows the impact that the ADA guidance will have on local governments that now must recalibrate their pavement preservation programs to accommodate the cost of compliance, or change strategies completely.
The survey was conducted in May by Ding Cheng, Ph.D., and Gary Hicks, Ph.D., of the California Pavement Preservation (CP2) Center at the California State University-Chico. Nearly 260 road professionals answered – of whom 62 percent were from local agencies, and 25 percent from state or federal agencies – and the survey found that more than 63 percent of respondents believe the new interpretation of what is considered alteration and what is considered maintenance will greatly impact their ability to maintain their roads.
Preservation treatments like micro surfacing, cape seals, thin and ultrathin HMA, and in-place recycling now are considered by the new rules to be alterations that will require curb ramps and amenities. More than 90 percent of respondents said they currently use these treatments, but 54 percent said they’d no longer use them in the face of the new ADA interpretation.
Would the new ADA interpretation lead to deferred projects? Some 65 percent of respondents said it would; 55 percent said it would increase the cost of roads by 20 to 40 percent, 34 percent by 40 to 60 percent, and 11 percent of respondents believe they will see 60 to 80 percent increases in their road costs.
Nearly 70 percent of respondents said the new ADA guidance will cause them to shift away from treatments that have worked well in the past, and 75 percent said it would lead to deferred maintenance.
“The new interpretation of what is considered as alteration and what is considered as maintenance will affect agencies’ ability to maintain roads,” Cheng and Hicks say. “Agencies may decide to no longer use surface treatments, such as microsurfacing, cape seal, or in-place recycling, if they require the installation of curb ramps. The technical advisory will cause agencies to defer preservation projects, and increase project costs by 20 to 40 percent or more.”
