Stone Bow Studios
I am trying to interpret the 703.5.5 table for text height for accessible parking signage. I am working on an ADA study and the custom / a-typical signage has small text - Unless the horizontal distance can be close to the sign. By identifying the text as non-compliant, I need to be able to point to why.
What horizontal distance should I use? I'm looking at the 21 feet but only because it's listed on the table. The text ht should be in the 40 - 70 inch range above ground & @ 21 feet, the minimum character ht should be 2 1/2 inches. ( The text may end up above the 70 inch range - especially with the Van Accessible sign )
With a sign mounting ht of 60 inches, I've read a guide that indicates this ht is set in order to allow the sign to be seen even while a car is parked in the space, does this mean that the intended horizontal distance is beyond the length of the parking space? If so, 21 feet would be the minimum and then only where the driver side of the vehicle is on the side of the parking.
There must be a better guide than picking an arbitrary distance to select a text height.
Any guidance would be appreciated.
Thanks,
Rob
Thanks,
Rob
