    Dismiss Notice
    Dismiss Notice
Adjacent property elevation
Discussion in 'Residential Foundation Codes' started by Lou, Jan 22, 2017.
  1. Lou
    Lou Registered User
    Jan 22, 2017
    4
    0
    Hello All,
    I plan to build a waterfront home in Pasco County Florida this year. The first floor elevation vs. the BFE is clear. My question is regarding the elevation of the parking “slab” under the first floor. I have not found what the elevation should be relative to the crown in the road, and more importantly can I match the elevation of a 1960's neighbors home which everyone suspects elevation is higher than current building code?
    Thanks.
    Lou
  2. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,067
    686
    That is a decision that can only be made by the AHJ. there is nothing in the building code that allows a deviation of a zoning code.
    Msradell likes this.
  3. steveray
    steveray Sawhorse
    Nov 25, 2009
    6,367
    837
    Talk to the AHJ....The building code likely does not care. As Mark indicated, zoning would have the answer and it should be on your site plan for them to approve...
  4. my250r11
    my250r11 Sawhorse
    Feb 16, 2015
    465
    137
    Ask the local floodplain manager, they can probably help you also. In general parking is okay but the construction of walls and egress need to meet certain requirement in flood zones.
  5. Lou
    Lou Registered User
    Jan 22, 2017
    4
    0
    Thanks for every ones input. I searched the local building code and Florida building code but couldn't find anything regarding the ground floor elevation relative to the road but I may not be using the correct search terms. Outside of an official answer neighbors have told me everything from soup to nuts. One response caught my attention, a friend told me the county could not object to my house's elevation matching a neighbors elevation due to water runoff and the close proximity to the houses.
    In any case I will update with what I find. Naturally I want to maximize the elevation due to frequent high tides and minor flooding.
  6. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    3,167
    290
    What is sites elevation relative to the coast and other standing/flowing bodies of water?
    Last hurricane through the area?
  7. Lou
    Lou Registered User
    Jan 22, 2017
    4
    0
    The elevation of the lot varies 2.2 - 4.9, I don't know if this is mean high water or mean water level. The area was hit with hurricane about 60 years ago, there was a flood in the early 90s.
  8. Paul Sweet
    Paul Sweet Sawhorse
    Oct 17, 2009
    1,076
    157
    It would be a local zoning or floodplain issue, not building code. Flood waters should be able to flow over the parking area, and not be diverted onto other properties.
    Have you had soil borings taken and evaluated? Some coastal areas have highly compressible muck far below the surface, and if you put in too much fill it will compress the muck and cause the ground to settle.
  9. Lou
    Lou Registered User
    Jan 22, 2017
    4
    0
    The geotechnical survey indicates I will need to drive pilings to support the columns. I haven't considered whether the slab will settle or not. The soil is mostly crushed limestone and silt from the canal dredging.
    The county refers to FEMA for floodplain management. I hope to get started this spring I should have more answers then.
  10. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    3,167
    290
    Sounds full of potential issues, consider your investment and intended length of stay. Can you get flood and hurricane insurance?
  11. north star
    north star Sawhorse
    Oct 19, 2009
    3,712
    239
    Lou,
    As others have mentioned, discuss this thoroughly with
    the AHJ and a certified Floodplain Manager BEFORE
    doing anything.........You may be opening up a very large
    can of expensive worms [ so-to-speak ].
    If you DO decide to pursue this, you should document,
    ...document, ...document and document some more.
    Get everything in writing.......The neighbor's elevation
    and property are not your primary concern.......Finding
    out for certain about your plans; in writing, should be.
    IMO, I strongly recommend that you perform a VERY
    thorough "Due Diligence Investigation" beforehand.
    Also, ...are you aware that Pasco County has a lot of
    Sink Holes ?.......This is one link to a map of Sink Holes
    in Florida.......There are other maps available online.
    http://www.earthtech.com/residential/sinkhole-truth/florida-sinkhole-locations/
    Are you sure that you really want to build here ?
    Talking about a true "Money Pit"... Aye carumba !
Share This Page
