wesley.foster@pacifi
You’re exactly right about how LADBS and other AHJs operate, and that’s the main reason why we’re not targeting building departments as the primary users of PlanCheckPro.AI. The reality is, AHJs are bound by red tape and bureaucracy, so adoption on their side will take time.Thanks, but I want to clarify.
The way I currently get out in front of standard plan check correction lists is to proactively co-opt them for my own purposes. See this example from Los Angeles Dept. of Bldg. and Safety for multifamily housing: https://dbs.lacity.gov/sites/default/files/efs/forms/pc17/PC.STR.Corr.Lst.18-(Rev.-01-01-2023)--.pdf
In the past, prior to initial plan check submittal, I've proactively printed that correction sheet, crossed out the non-applicable comments, and handwritten next to each comment where the answer could be found on the initial plan check submittal. I upload that pre-responded correction sheet at time of first plan check, effectively saying to the plan checker, "we already did your work for you, so don't waste our time by not looking closely during initial plan check".
Assuming for the moment that LADBS will not embrace any AI plan check program in the near future ( no fault of yours, it will just be due to the typical power plays at city hall), your program could still have value at time of initial plan check by publishing their checklists with the responses ("where to find it") already on them.
In other words, a totally clean set of plans with no correction printouts from your program will not convince a manual plan checker that it complies with code, they'll just be wondering if you missed something; thus it will not save them any time (until the day comes that they fully trust your program). However, a standard correction list already cross-referenced to where the compliance can be found on the plans WILL be more productive within the context of their current bureaucracy.
Our focus is on the people who feel the delays most: owners, contractors, architects of record (AORs), and engineers of record (EORs). These are the users who want to submit a cleaner set of drawings the first time, avoid boilerplate correction cycles, and keep projects moving without unnecessary RFIs and resubmittals.
So to be clear: PlanCheckPro.AI isn’t trying to convince AHJs to change overnight. It’s giving project teams a way to stay ahead of the curve, reduce friction at submittal, and save real time and money in the process.
