I have read it and it does not specify a time frame for achieving compliance and if the business can not afford it it does not need to be done contrary to what some believe. It could take a mom & pop shop 50 years or longer as long as they have a plan and are working towards that plan.
easily accomplishable withoutmuch difficulty or expense
. The“readily achievable” requirement is based on the size and resources of the business. So larger businesses with more resources are expected to take a more active role in removing barriers than small businesses. The ADA also recognizes that economic conditions vary. When a business has resources to remove barriers, it is expected to do so; but when profits are down, barrier removal may be reduced or delayed. Barrier removal is an ongoing obligation --you are expected to remove barriers in the future as resources become available.
