cballinger
Bronze Member
I don't post much, and I know this question has been posed before, but I didn't find the answer I'm looking for on those threads and wanted to start a new discussion. 2012 IMC adopted. The age old question - Type I hood required over wood-burning pizza oven? Here are the specs and installation manual for my particular case:
http://www.fornobravo.com/PDF/napoli/napoli120_dims.pdf
http://www.fornobravo.com/PDF/commercial_install.pdf
Listed to UL737 and UL2162. Manufacturer allows EITHER a UL103 Type HT listed chimney OR a Type I hood. IMC Section 507.2 requires a Type I hood for "commercial cooking appliances". Working backwards from the listings, I see the requirement in 917 for commercial cooking appliances to be listed in accordance with UL 2162. I also see in Section 905 the requirement for fireplace stoves to be listed in accordance with UL737. So this is listed as a fireplace stove and as a commercial cooking appliance. It would also be my understanding that the Direct Vent method would comply with the requirement for UL737 for fireplace stoves, and the Type I hood would comply with the requirements in UL2162 for commercial cooking appliances.
If this can be either/or, is there anything in the IMC that says I can't cook pizza in a fireplace stove? If not, then I'm inclined to say they comply with the requirements and don't need to install a Type I hood.
