JZegowitz
I hope this is posted under the right category, I often read but this is a first post! The question is regarding surface garages built in MA associated with an apartment complex. MA goes by 2015 IBC w/MA amendments, none applicable to these buildings. These are typical stand alone 12 and 7 unit garages; side by side 22'x12' (+/-) stalls with individual overhead doors located on the site with no issues regarding fire separation distance. My read is that these fall under the Utility use group, private garages and require 1 hour separation assemblies between each stall. Experiencing pretty heavy push back quoting S2 use group, saying no separation required. I've used that line of reasoning in previous projects where ground level parking under R2 or underground parking under R2, but then follow the public garage requirements of sprinklers, O2 exhaust etc. Is there a path that allows Type 5B wood frame multi-stall garage with no separations or sprinklers/O2 exhaust? Thanks for your help, I always find the discussions helpful!
