globe trekker
- Joined
- Oct 19, 2009
- Messages
- 1,739
Does this Article require a separate GFCI rated circuit for the roof mounted HACR
equipment, or just that the electrical outlet not be connected to the load side
of the equipment.
QUESTION: If the Article does not require a separate (i.e.- meaning a separate
circuit from the equipment circuit) rated circuit for the servicing & maintenance,
what happens if the circuit for the equipment goes down or is otherwise
out-of-service. The electrical receptacle for servicing & maintenance of
the roof mounted equipment also is out-of-service.
Ya'lls thoughts!
of the equipment.
Ya'lls thoughts!
