dsoedharmo
Hi all,
I am working on a tenant fit out for Business use that have rooms/areas with assembly function (e.g: conference room, lounge area, breakroom, etc.). Each of this room/area will have occupant load less than 49 people, but combination of all these assembly function rooms/areas will have occupant load more than 49 people.
My question is...will a panic hardware be required on exit doors from this suite?
I heard 2 different answers:
- 1st said that if none of your room with assembly function has more than 49 people then panic hardware will not be required.
- 2nd said (actually from code commentary)..." a door that provides means of egress for two or more such rooms (assembly) would require panic hardware or fire exit hardware where the combination of spaces has a total occupant load of 50 or more."
Thank you!
Thank you!
