jetlag1946
High . Does any one know the proper procedure to attach a 2x10 treated ledger for a deck to the side of a house into the side of a web floor truss ? It is not the usual end truss that has the vertical webs , because it had to span over a garage door opening and has the angled webs . The 2007 IRC code said to consult the truss designer about that . On a regular frame house the want 1//2 bolts all the way through the band joists . Im sure they dont want a 1/2 " bolt hole drilled in a truss web over a span . I dont know who the tuss designer was but Im sure they would all use the same method, A web floor truss is the same no matter where you buy it .The outside of the truss has 1/2 plywood nailed on and the inside is just open web .
