As described above, it is the attic for the first floor space whose footprint extends beyond the second floor space. If we disregard that, we could still say it's beyond the scope of what the authors were thinking of when they wrote the definition for a typical post WWII home. In either case, the intent seems the same to me.It's not an attic
All bets are off is there is a fire burning. If they are doing a smoke/odor investigation, though, they'll use the access. Tearing the ceiling down before you know there is a problem will cause phone calls to the chief. Kind of like a Knox box - they'll take the time to get keys if investigating an alarm signal, but if there's a fire, they'll use other means.the FD guys are going to put a hook in the ceiling and tear the whole darn thing down rather than use the access.
You left a condition off which changes things. If you can't realistically get far enough in to take a look around, then there is no point in providing an access.All of those conditions apply to a space less than 30" high to exactly the same degree.
I disagree with your position that avoiding installation of access means no storage can be placed in there. If someone wants to store something, they'll put their own access in. Better to make sure it's done correctly from the get-go. I've seen some incidental storage in attics, but not generally to the point that I feel the threat of fire outweighs the benefit of an access. Based on your logic, we should simply prohibit attic access in all cases. Maybe we should prohibit doors into homes, too. After all, I've seen hoarders stack their entire living space to the ceiling with trash which wasn't accounted for in the design of the home.In other words, your zealous enforcement almost certainly increases the hazard.
I left off a condition, and you missed the point. No access = much less probability of storage (including combustibles) in a place which was not designed to accommodate it.permitguy said:You left a condition off which changes things. If you can't realistically get far enough in to take a look around, then there is no point in providing an access.
My logic is that in marginal cases, the risks outweigh the concerns...and if a little lumber can be used to meet the letter of the code to prevent some Building Official/Zoning Official from forcing the designer to increase the risk, then that's a good thing.permitguy said:I disagree with your position that avoiding installation of access means no storage can be placed in there. If someone wants to store something, they'll put their own access in. Better to make sure it's done correctly from the get-go. I've seen some incidental storage in attics, but not generally to the point that I feel the threat of fire outweighs the benefit of an access. Based on your logic, we should simply prohibit attic access in all cases. Maybe we should prohibit doors into homes, too. After all, I've seen hoarders stack their entire living space to the ceiling with trash which wasn't accounted for in the design of the home.
After reading the twisted logic behind so many attempts to bully the public on this board, I am saddened that so many posters are code officials.TJacobs said:I get a kick out of reading some of the outrageous attempts to avoid reality on this board. Makes me glad not all the posters are code officials.
or as common sense would dictate.fatboy said:Otherwise, enforce the code as it is written, or locally amended.
Actually, IMO, we DO get to pick & choose!Just saying we don't get to pick & choose.
That assumes the building official knows the intent and purpose of this code......... based on some posts,I question thatnorth star said:.......The building official shall have the authority to render interpretations of this code and to adopt policies and procedures in order to clarify the application of its provisions.........Such interpretations, policies and procedures shall be in conformance with the intent and purpose of this code.........
Regardless, the BO still has the authority to render their own interpretations.......Mark,I agree with you that some BO's are less than competent and not qualified to be a BO,That assumes the building official knows the intent and purpose ofthis code......... based on some posts, I question that.
Education, Experiance, incompetencePcinspector1 said:I was wondering if the DP or plan reviewer would have picked up on the attic or consealed space acces or not at plan review?pc1
DP on an SFR?Pcinspector1 said:I was wondering if the DP or plan reviewer would have picked up on the attic or consealed space access or not at plan review?pc1
It's not enforcement of the letter of the code which is bullying.permitguy said:Ignoring application of the code because you think it makes you a bully is not the same as rendering an interpretation. If one doesn't have the intestinal fortitude to require installation of a simple attic access, I shudder to think how one handles corrective action of something that is difficult or costly.Luckily, those who are ever-yielding to contractors and designers in their enforcement are the extreme minority in this business.
Flame away. I'm done with this one.
Is it the attic does not have access or just this small portion of it? It is not a matter of intestinal fortitude for some it is a matter of application of the code. The attic has to have a minimum access size. There is no code requirement that all portions of the attic have to be accessible by a minimum size opening unless there is mechanical equipment located there. I would look at this to determine if some one could access this space through the framing before requiring an access door to this small area. More pictures would be helpfullIf one doesn't have the intestinal fortitude to require installation of a simple attic access, I shudder to think how one handles corrective action of something that is difficult or costly.
