BEST LED flash light? Suggestions?
wfd1366
Member
Looking for a new flash light to carry on inspections. I still use the old school mini mag light. Looking for something similar in size but LED and I can turn on with a button instead of rotating the head (like a mini mag). Thanks, Mike
Mike,
I use this, really like it, small and bright, about $40, got it at Lowes.
Coast PX45 Focusing LED Flashlight, 212 High Lumens, 61 Low Lumens
I have a couple of these. Love them.Make sure you pick up a few batteries and charger. I won't paste a link to the site, but you can google what you see here...UltraFire C8-T6 Cree XM-L T6 800LM 5-Mode White LED Flashlight (1 X 18650)
They ship out of Hong Kong, product and prices are great.View attachment 977
/monthly_2014_01/sku_110264_1.jpg.ea8aaa35c821b053c75b583ac1cd6a7d.jpg
I use a Streamlight C4 Twin Task. A little pricey but nice beam spread. It also has selectable UV which comes in handy when the UV PVC primer has been used. THe contractors usually have cheap UV lights; the C4 is bright enough to be used in most lighting situations.
Tim
I have a couple Cree Mini's and they are AWESOME little lights for the price ($5 and free shipping), and put out plenty of light for most inspection work. You can use a regular AA battery or a 3.7V battery that is the same size as the AA. Just Google "300lm Mini Cree Led Flashlight" and you can do a little checking for yourself.
Streamlight Pro Tac HL, inspection to gun mount - do it all flashlight
Streamlight's first hand-held, lithium battery-powered programmable flashlight that provides 600 lumens of light with 253 meters of beam distance.
Specs and Features:
•Ten-Tap™ Programming – Choice of three user selectable programs:
•High / strobe / low
•High only
•Low / high
•C4® LED technology, impervious to shock with a 50,000 hour lifetime
•Three light output levels:
•High – 16,000 candela peak beam intensity, 600 Lumens, 1.25 hours runtime
•Low – 800 candela peak beam intensity, 33 Lumens, 18 hours runtime
•Strobe - 2.5 hours runtime
•Multi-function, push-button tail switch for one-handed operation
•Optimized electronics provide regulated intensity
•Durable anodized machined aircraft aluminum construction
•Anti-roll head prevents the light from rolling away when you set it down
•Removable pocket clip
•O-ring sealed glass lens
•IPX7; waterproof to 1 meter for 30 minutes
•1 meter impact resistance tested
•Uses two 3V CR123A lithium batteries (included)
•Includes nylon holster
•Barrel diameter: 1.0" (2.54 cm)
•Length: 5.40" (13.7 cm)
•Weight: 5.6 oz. (159g) with batteries
•Limited lifetime warranty
Mine says "LED Lenser" on it, I got it at Home Depot a couple years ago for like $45. It seemed like a lot then, but since it's lasted a few years it's more than paid for itself. It's about 4" long, operates with a button on the end, and has been dropped quite a few times and held up so far. It also runs on triple A's rather than those more expensive specialty batteries. When it starts going dull though, sometimes I don't realize it until I'm bonking my head in a dark basement. When it's got new batteries, it's shined all the way across a huge old boarded up theater.
