Brain Tease Electric Range
What size copper wire if using NM cable would be needed to supply:
1) An Electric Range 12.5 kVA
2) An Electric Range 8 kVA
The IRC Applies in this instance
Tell us how you arrived at your answer..................
Me being an instigator times a wasting!
Q-1) Answer; 8-3
2006 IRC E3602.9.1 Ranges with a rating or 8.75 kVA or more shall be supplied by a ranch circuit having a minimum rating of 40 amperes.
E3605.4.4; The ampacity of Types NM... cable shall be at 60 degrees C conductors and shall comply with Section E3605.1 and Table E3605.5.3
Q-2) Answer; 8-3
8kVA is 8 * 1000 / 240 is 33 amps
I could not find in the IRC where Kilovolt-amperes (kVA) shall be considered equivalent to kilowatts (kW) for loads computed under this section. 2009 IRC anyone?
The greatest mistake we make is living in constant fear that we will make one. - John C. Maxwell
