Amazing Arthur's whole quest wasn't immediately shut down, and he wasn't subsequently fined by OSHA. And to mention, or think of, all the building code violations that occured in the first three castles that were built on the swamp, but sank. Whose AHJ is that? Did they every fall asleep at the wheel. Could have used a Brother Maynard there if you ask me, Yes indeed they could have.brudgers said:I think you are on to something because even after being told exactly what was required, Arthur still got it wrong.
Well then there thoust shall be, at a minimum, a fire separation between the stage and the changing and rehearsal rooms.Lurker said:It's only a model.
A castle is a man's home, and therefore it would fall under the IRC, which in some forums would imply that yes, the interior stairs should at least comply for handrail and guardrail requirements.brudgers said:What about all those stairs without handrails?
How exactly does one define grade plane for a swamp? Secondly, isn't the structure designed to sink into the swamp. Couldn't we just give it a bit, and then inspect it as a two story castle with one story below swamp grade?JBI said:It's more than three stories above grade plane, so NOT a ResCode building... an R-3 in the IBC, therefore sprinklers required.
brudgers...I am assuming that what Brother Maynard is implying is that Holy Grail shaped beacon shall be a minimum of three, but no larger than five. Is that what you got out of the code too?Cistercian monk Brother Maynard said:Dear Brave Sir Brudgers,
I believe this passage as read by Friar Pan, should provide answer and insight for your question"
Book of Armaments, Chapter 2, verses (also known as sections) 9-21, “ ...And Saint Attila (patron saint of inspectors) raised the hand grenade up on high, saying, "O LORD (building official) , bless this Thy hand grenade that with it Thou mayest blow Thine enemies (code violators) to tiny bits, in Thy mercy." And the LORD (building official) did grin and the people did feast upon the lambs and sloths and carp and anchovies and orangutans and breakfast cereals, and fruit bats and large chu... [skiping a bit]... And the LORD (building official) spake, saying, "First shalt thou take out the Holy Pin (Anchor Bolt), then shalt thou count to three, no more, no less. Three shall be the number thou shalt count, and the number of the counting shall be three. Four shalt thou not count, neither count thou two, excepting that thou then proceed to three. Five is right out. Once the number three, being the third number, be reached, then lobbest thou thy Holy Hand Grenade of Antioch towards thy foe (code violators), who being naughty in My sight, shall snuff it." Amen.
