Mule:
Engineers and Architects with stamps are not always infallible, and some of them are downright lazy and careless with what they do and spec. It seems to me that you have some obligation to call out the things that you think don’t meet the code. I think you also have some obligation to point out the details in question, cite the code sections you think have been violated, and ask for further explanation from the Engineer, and at this stage calcs. and detailed confirmation of meeting your cited code sections. Remember, in many cases there are several ways to skin the same cat. I don’t usually expect that I have to supply calcs. for everything I design, particularly when my plans, details, written or verbal explanations are reasonably well thought out. But, when there is a question, I would sooner work with you as long as we are both being reasonable, than go out of my way to antagonize you. Maybe you can help the Engineer a bit, by backing him on the need for the extra effort and cost, because without a doubt, the builder came to him and asked that this be done in an hour, without implicating the builder’s original errors. You’re trying to help fix the builder’s bulls and the costs would have been his if he had done it right in the first place, although maybe a bit lower.
Do let us know what the SIMPSON Engineers have to say when you show them the areas that you are questioning. Just as we harp about builders and drafters/designers overstepping their experience and engineering abilities, we should expect a reasonable level of quality and attention to detail and the codes in the work done by Engineers and Architects or they should be called out on the lack thereof. By this stage the file indicates that this has gone back and forth a time or two and your name is on every other interaction, so if it’s wrong you can’t ignore it now, without putting your own reputation and authority in question.
